Best balance of boost and compression for a DD
The gn guys upped the compression to 9.5 on some of the motors, but that was for big turbos, loose 9/11 converters, and a v6 so it needed some bottom end help.
I'm like Jerry and the majority 8:5 to 9:1 is about max.
Originally Posted by vanillagorilla
JE makes them!
... and I wouldn't go with anything higher than .054 head gasket thickness.
Bill
Tin Foil Hat Wearin' Fool
JE's are nice, total seal or hellfire rings, and thinner head gasket will not only be stronger but in most cases better quench too. If it was me I would go with a 9:1 motor, Im not willing to change pistons in my setup to the best I can get it is 9.3:1 by going from 62cc combustion chambers to 71s.
8.5-9.0 on a DD 408. The 408 will produce plenty of low end. Diamond pistons are heavier in most cases but they have revised their design recently and using a narower wrist pin and have lightened the pistons by 40-50 grams in most cases. But you can't go wrong with JE pistons.
Originally Posted by thunder550
What material type for the rings? I see chrome, plasma-moly, moly, and iron.
Plasma moly and chrome moly rings are the norm and iron second rings. A regular iron ring doesnt have the durability to last in a compression ring configuration. There is a reason why they are no longer used as a compression ring much less on a high boost application. Im no engine expert but over on tech I havent seen ANY of the big engine builders use a stright iron ring for the compression ring.
