Best turbo engine?
Depends on what you want from it. Gonna need a far bit of cubes if you want it to spool quickly. Definitely could use a something north of 400. I think NP had a truck with a 370 with that turbo if I remember right.
Is this a something you plan to put a lot of miles on? IMO, it's tough to beat a well built 365-370 for power AND long durability. Strokers will make more power, but I have seen far too many people having issues with piston skirt wear and oil consumption when used as a dd in a heavy truck. A well thought out forged 6.0 can get you well over 750rwhp that will also last for lots and lots of miles. I built my 365 at 10:1 comp. with 4032 pistons, and bone stock 317's and stock truck intake and tbody and make 650rwhp and run low 11's with no traction at only 13 psi. At 18psi and better traction, I'm sure it will be even more fun! The 4032 pistons make it quiet due to being able to keep the piston to wall clearance tighter, and last a long long time.
What about halfway in between? 390?? I'd love to do a LSX 427 but that will cost alot to build. Unless I can get some decent money for the used stuff.
