Best type of Heat Exchanger for air to water system?
Originally Posted by TG02Z71
Makes perfect sense, I guess using the motorcycle radiator has an added benifit. A CAP where you can fill the system and periodically check it!
Originally Posted by duner
If you used a motorcycle radiator as your primary heat exchanger, you would just need to have it at the highest point while filling it or add a spot to "burp" the system if you mounted it low.
Thanks, Tim.
Duner, do you happen to know how high the heater core is relative to the inlet and outlets on the fire wall? Just wondering since I would like to keep my small radiator mounted the highest as you say.
Thanks, Tim.
Thanks, Tim.
silverstreak07
06-28-2016 07:29 PM
05GMC4.8
08-07-2015 10:55 PM
air, bubbling, conditioner, conditioning, excessively, exchanger, fluid, ford, heat, intercooler, lightning, trailblazer, tricks, trucks, units, water
