Blow by again????????
Old 03-11-2009 | 04:38 PM
WJ MARK's Avatar
Default Blow by again????????
Ok as most know I swapped out the 5.3 due to oil blowing out my dip stick. Conclusion #7 piston broken ringlands Now I have a newer 04 Lq4 that is leaking oil past the o-ring on the dip stick Ive been stressing like crazy that I have the same problem again. Did a compression check and found all cylinders to be fine @ 120 psi, what is normal for these???? I have a catch can venting both valve covers, pcv deleted, plugged off the TB. what gives???? could my rings be warn????? I think the motor may have sat for a while maybe it will get better over some time
Any suggestions
Old 03-11-2009 | 04:41 PM
00ChevyScott's Avatar
Wearin' da big hat
I thought they were suppose to be at 180 psi..?
Old 03-11-2009 | 04:44 PM
WJ MARK's Avatar
Also we did a break stall to build some boost with the dip stick out to see how much was comming out. When you would let off a really small squirt would come out. Its not blowing out my dip stick , just oil getting past the o-ring. I doubled the o-ring with 2 little ones and seems to have stopped the oil from comming out. Im all out of ideas
WJ MARK's Avatar
I think my 5.3 was around 120-125??
Old 03-11-2009 | 04:52 PM
BlackGMC's Avatar
Resident Retard
I think a Leak-down-test is better for checking out messed up rings..
Old 03-11-2009 | 04:54 PM
D_reks{5.3}'s Avatar
i thought it was suppose to be at 180psi.. Jaegmc99 did a compression test on his 5.3 with about 170k miles on it a month or so ago and i think his were at 180psi and everyone said it was normal. Could be wrong tho...Hopefully you get it straightened it out.
Old 03-11-2009 | 04:56 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
My old 180K mile 5.3 tested out to a little over 170psi...
Old 03-11-2009 | 05:00 PM
silver-mod-o's Avatar
Hunt&Fisherator
Same here, except #7... Which was obviously smoked LOL
Old 03-11-2009 | 05:11 PM
Doobie's Avatar
If you did the compression test on a cold motor, it will indicate lower than on a warm or hot engine.
Old 03-11-2009 | 05:13 PM
charcold-bowtie's Avatar
my 4.8 would do around 145 psi
