Blow off valve ratings for my set up?
I have the STS BOV. It is a 38mm TiAL AFAIK. It is definately a TiAL BOV. It comes with a new powder coated intake pipe with a mount already welded on and has an 11# spring in it. It is a nice piece and installs just before the MAF. I would consider it while you are looking. it will only open when you back out of it at WOT and your vacuum goes below -11# on deceleration. If you can hear it over the turbo screech you will be lucky.
How do I change this text
Originally Posted by vanillagorilla
So your turbo still flutters despite having a BOV?
Are you sure that sound is the WG and not the compressor wheel? I'm going to be going with STS's BOV and I'm having second thoughts after hearing this. I NEED a BOV that works, as I'm putting in a T56 next week.
vanillagorilla, I still get the compressor surge when I back out of it but I thought it was doing something. Because of that I am not sure if it is working properly or not. The boost gauge shows I am getting -11.xx# so it should be opening but I have no way to actually test it. It gets its vacuum signal from the same line as the boost gauge so it should be working. I could not connect mine to the brake booster line because I have the hydro assisted brakes.
Have fun with the T56.
Originally Posted by kbracing96
I just used a cheap Bocsh bypass valve off a Volvo. It's only 1 inch, but it took me from 6-7 woop woops to 1 or 2 and a woosshhh (almost needs 2 of them). It cost me a buck from ebay and filter off the valve cover of my old stock car, but it works
I know a couple of cool ricer guys and one told me he could get the same thing your talking about for free. He's got a buddy with a salvage yard.
