Blow off valve ratings for my set up?
Old 12-21-2005, 01:19 PM
sliderbkt's Avatar
My Combination Motorsports kit cam with a Turbonetics Raptor. I think it is rated to 500hp but I'm not sure. It isn't vey loud, which is a plus for me.
Old 12-21-2005, 01:23 PM
Mort's Avatar
Cool
I have the STS BOV. It is a 38mm TiAL AFAIK. It is definately a TiAL BOV. It comes with a new powder coated intake pipe with a mount already welded on and has an 11# spring in it. It is a nice piece and installs just before the MAF. I would consider it while you are looking. it will only open when you back out of it at WOT and your vacuum goes below -11# on deceleration. If you can hear it over the turbo screech you will be lucky.
Old 12-21-2005, 01:27 PM
vanillagorilla's Avatar
So your turbo still flutters despite having a BOV?
Old 12-21-2005, 02:29 PM
How do I change this text
Wilde Racing's Avatar
Mine does. , I think the people who have ran with and with-out said it helped the waste gate flutter (or sprinkler sound) but I'm not sure, I just know mine does with the STS tail BOV, But I like the sound of it (ALL)
Old 12-21-2005, 03:12 PM
Are you sure that sound is the WG and not the compressor wheel? I'm going to be going with STS's BOV and I'm having second thoughts after hearing this. I NEED a BOV that works, as I'm putting in a T56 next week.
Old 12-21-2005, 06:05 PM
Mort's Avatar
Cool
vanillagorilla, I still get the compressor surge when I back out of it but I thought it was doing something. Because of that I am not sure if it is working properly or not. The boost gauge shows I am getting -11.xx# so it should be opening but I have no way to actually test it. It gets its vacuum signal from the same line as the boost gauge so it should be working. I could not connect mine to the brake booster line because I have the hydro assisted brakes.
Have fun with the T56.
Old 12-21-2005, 07:34 PM
There is a way to test it I just straped a video cam under the hood.....................Mine works
Old 12-21-2005, 09:56 PM
kbracing96's Avatar
I just used a cheap Bocsh bypass valve off a Volvo. It's only 1 inch, but it took me from 6-7 woop woops to 1 or 2 and a woosshhh (almost needs 2 of them). It cost me a buck from ebay and filter off the valve cover of my old stock car, but it works
Old 12-22-2005, 06:03 AM
TG02Z71's Avatar
Hmmm, sounds like a good alternative for the budget. Thanks for the info.
I know a couple of cool ricer guys and one told me he could get the same thing your talking about for free. He's got a buddy with a salvage yard.
Old 12-22-2005, 11:27 AM
Scott Mills's Avatar
I am using a Greddy nock-off from Ebay type RS style. I think it is a 38mm bov and I dont get the sprinkler sound any more.
Quick Reply: Blow off valve ratings for my set up?
