blower belt fell off
Old 02-21-2012 | 12:25 PM
  #21
blwn4.8's Avatar
Originally Posted by ayousef
6 or 8 rib?
I had the same problem and changed out my idlers and problem fixed! Mine is a 6 rib. I also went ahead and put in the HD tensioner to loose the belt slip. Give that a shot and I bet your problems will be solved
Old 02-22-2012 | 01:03 PM
  #22
terravast4's Avatar
I bought some 8 rib 100mm idlers off ebay that have double bearings in them so they stay straight and wont wear out. I have also broken a HD tensioner already.
Old 02-25-2012 | 07:43 AM
  #23
Pocket's Avatar
anyway to prevent this?
I came up with an idea, I will jack up the idle airflow in the tune at high rpms so the throttle doesnt shut completely that quick and will instead keep some momentum, thats what my ZR1 used to do.
Any mechanical way to prevent this? Any point in switching to an 8rib and an HD tensioner?
Designing an independent drive for the SC is ideal but expensive. Abrupt throttle changes throw belts frequently, just a nature of the SC. With an independent belt, you can toss the SC belt and still limp where you're going. A stronger tensioner and higher flange pulleys help, but are no permanent fix
Old 02-25-2012 | 09:18 AM
  #24
terravast4's Avatar
Yep....it takes a while but you actually "learn" how to work the gas pedal correctly to keep this from happening.
Old 02-25-2012 | 04:52 PM
  #25
Pocket's Avatar
It took a few tosses for me to get the "roll out of the throttle" notion too
Its a good idea to keep a spare belt and wrench in the car because sometimes you just have to do it and theres always a risk of the belt being eaten
calsdad
06-14-2023 11:07 PM
Gadgetized
10-22-2015 09:06 AM
SlvrSierra4.8
10-01-2015 09:39 PM
murderedSS
09-27-2015 10:16 PM
hackrst
09-02-2015 05:27 PM
Quick Reply: blower belt fell off
