blower strips?
1136cid is 18.3 liter motor....If a 1671 will feed THAT I'm betting you could see 50psi with a blower that big on a 6.0 !!!, just imagine the firehoses you'd have to inject fuel with !!!
Back in my serious drag racing days, we used to run the 1471 blower on the variation of the big block chevy/Olds/Pontiac engines in NHRA Top Alcohol Dragster. They were a high helix design, and had nylatron strips. Used to have to re/strip after almost run, if you wanted to make good power. Everybody had a tool that you put in a vise to hold the rotors to do the job. Man.....I used to cut the **** out of my fingers doing the job between rounds. The grooves are machined perfectly square, and the nylatron had the be drawn thru the grooves to get it in. Brings back memories!! By the way, we were spinning them around 125% over, the motor was singing about 10,500 going thru the traps. I don't know what the actual boost was, that wasa before all the high tech data loggers.
