blower strips?
Old 06-15-2006, 03:28 PM
Whippled 496's Avatar
Originally Posted by Yelo
A 1671 blower was designed for a 1136cid motor !!!....can you imagine the boost it would be able to push into a 6.0 !!!
3psi?
Old 06-15-2006, 03:31 PM
blownerator
BlownChevy's Avatar
Originally Posted by Linda
3psi?
we are not talking Screw blowers
Old 06-15-2006, 04:03 PM
03sierraslt's Avatar
Old 06-15-2006, 04:11 PM
blownerator
BlownChevy's Avatar
just
Old 06-15-2006, 04:25 PM
Yelo's Avatar
1136cid is 18.3 liter motor....If a 1671 will feed THAT I'm betting you could see 50psi with a blower that big on a 6.0 !!!, just imagine the firehoses you'd have to inject fuel with !!!
Old 06-15-2006, 09:46 PM
Originally Posted by BlownChevy
just
I know, same here.
Old 06-15-2006, 10:54 PM
LMAO, nice. One more crack like that and im reporting you to a MOD.
Old 06-16-2006, 02:15 AM
blownerator
BlownChevy's Avatar
Ok, my bad
Old 06-16-2006, 09:00 AM
wkdivr's Avatar
Back in my serious drag racing days, we used to run the 1471 blower on the variation of the big block chevy/Olds/Pontiac engines in NHRA Top Alcohol Dragster. They were a high helix design, and had nylatron strips. Used to have to re/strip after almost run, if you wanted to make good power. Everybody had a tool that you put in a vise to hold the rotors to do the job. Man.....I used to cut the **** out of my fingers doing the job between rounds. The grooves are machined perfectly square, and the nylatron had the be drawn thru the grooves to get it in. Brings back memories!! By the way, we were spinning them around 125% over, the motor was singing about 10,500 going thru the traps. I don't know what the actual boost was, that wasa before all the high tech data loggers.
Old 06-16-2006, 03:50 PM
11 Second Truck Club
Superado's Avatar
sort of related to this thread...
http://www.theclashofthetitans.com/i...JoelCasper.mpg
Quick Reply: blower strips?
