Blowing oil out
Blowing oil out
I believe I may be blowing oil out from the oil cap, it never seemed to sit on completely tight. Has anyone ever experienced oil blowing out from in between the valve cover and heads?
What would the remedy be for this? Run the catch can from one valve cover to another, and then put a small filter on top of the oil cap using a fitting to hold it in place?
Performance Trucks Sponsor
I know you have the sts and is your oil return line still on the cap?
If so, tap the valve cover and put it there.
Almost every cap that has the return there seems to leak just a bit. It's just not a tight seal or sturdy enough to support a hose.
