Boost bet with MAF or SD?
Tin Foil Hat Wearin' Fool
Real rich spike when method comes in I believe. It's been a while since I've seen Jake post anything about it and I honestly didn't pay much attention since I drove an old school truck back then. Now that I've got a newer truck and I would like to boost it I'm paying a bit more attention.
Mod with training wheels
I'm working on all kinds of crap Hopefully get some or all of it finished this summer. Simple solution for running an Alky control meth kit is running SD. Since Julio uses a MAP sensor to determine how much meth to deliver, it basically runs on SD itself. Much easier to pull out fuel to add meth based on MAP, vs MAF. Otherwise you risk running into the problem of high rpm and low/no boost where you've pulled fuel in the upper MAF range, so it goes lean without the meth. Conversely, if you're lugging up a hill in OD at low RPM and load the turbo, meth can kick in a bunch as boost rolls in without a lot of fuel being demanded and make it pig rich.
Looks like I'll be running that same AL block engine that is in your new truck Cody, I'll let you know how much it takes lol.
