Boost the Boost
#22
I've been told that anything smaller than 3.1 on a 5.3 is a waste of time. I think I'm going to try the 3.1 to take advantage of the good fall weather, too. I think a touch up on your tune would help a ton on your combo. I ran a best of 13.24 @102 with Drag Radials last night. With your converter, you should be seeing 1.8 60' times.
#23
Pulled 1.9X 60 ft times last time at track in 95+ degree heat.
#24
Got the pulley in and on. Boost is now back up to about 8.5 psi. Couldn't find a smaller serpentine today so had to put the original back on. Got a GatorBack on order. So far so good. Can't wait to get to the track, really hoping to pull some solid mid to low 13's in the cooler temps hanging around.
