Boost Cam
Boost Cam
I have a trick stage 2 kit and a low km all stock 5.3.
I would like to run a bigger cam, I was looking at the Brian Tooley stage 2 boost cam. 226/231 .605"/.598" 113+4 3 bolt.
I know a lot of people have had great result with the triple 12, but I would like something bigger.
What are the cam limits on a 5.3?
Thanks.
Thanks.
Slowest turbo build ever!
My theory with cams and turbos, and I think others will approve, is that turbos don't really care what cam you use. But being in our heavy *** trucks, its best to get a cam that will help your low end torque, but will still allow the turbo to breathe once it hits full boost. Something like the triple 12 cam makes good low end torque, but allows the turbo and engine to pull all the way to 6k and a little above. A big cam will for sure let the turbo works its magic, but your gonna need a healthy converter to make it all work.
