Boost Cam
Old 11-12-2013, 06:30 PM
Slowest turbo build ever!
black00chev's Avatar
Originally Posted by Atomic
That sounds familiar
it should... between you, Jarret, and Kyle proving and reiterating it all the time .
Old 11-12-2013, 07:44 PM
Iconoclast's Avatar
Its a RCSB 2WD Not THAT heavy for a truck.
I plan on putting a 3k stall in it, stock for now. The plan is 650 lift springs and push rods, maybe work the 862's a little as well down the road.
Old 11-12-2013, 07:49 PM
Resident Retard
BlackGMC's Avatar
I think my cam does pretty good in my truck.
Old 11-12-2013, 08:09 PM
Op, I ran 10.97 @ 125 with a TU1, th400, 3.42 gears, bones stock heads, intake and tb, with a tiny 76/64 on3 turbo on 14 psi on pump 93. No longer running that turbo bc it was done at 14 psi but it was enough for 10's
Old 11-12-2013, 08:25 PM
Iconoclast's Avatar
How much power are you making?
Old 11-12-2013, 10:00 PM
gamble686's Avatar
Proven boost cams come from isky and speed inc. A bunch of other people make "boost" cams, but they all seem to perform about the same. Isky and speed inc are the only ones I have seen prove their value over other cams.
Old 11-13-2013, 01:24 AM
Iconoclast's Avatar
Took a look at speed inc, they have a 228/228 turbo cam as well, TU1.5
I might be able to have my cake and eat it too..
I dont understand what makes a cam a turbo cam..People claim say.. an ls9 cam 211/230, is better for boost..other say 212/212. You would think a boost specific cam would be one way or the other..whats the pros and cons of having a split number cam?
Old 11-13-2013, 03:43 PM
That pass was probably ~625-650 rwhp. That TU1.5 sounds good, it wasnt available when I got mine, if it was I probably wouldve went that route
Old 11-13-2013, 07:52 PM
shifty89's Avatar
Low overlap, reduce cylinder bleed off and reversion. Generally don't need a bunch of duration. It's forced induction so you don't need to try and scavenge as much as possible on the intake stroke as a NA setup. A duration split slightly favoring the exhaust doesn't seem to hurt. Least that's my idea and understanding of a boost cam.
Old 11-13-2013, 07:57 PM
03sierraslt's Avatar
Understand that supercharger boost and Turbocharger boost are not the same when it comes to cams. Turbos are a bit less picky IMO with cam specs, a supercharger typically likes more duration on the exhaust side as the intake side is being forced in and the exhaust size needs a bit more time to clear out. Myself I would never run a LS9 cam with a turbo, granted people have done it but that does not mean that it is the best choice. Out of the two you mentioned I would run the 212 cam hands down any day of the wk over the LS9 with a turbo.
Quick Reply: Boost Cam
