Boost Cam
Old 11-13-2013, 09:24 PM
  #21
I have a gauge for that
Atomic's Avatar
With the backpressure a vast majority of the setups here have I would select a cam with single duration or a very small exhaust bias. I had a 226/226 on a 117 and loved it. Now I have a 230/233 114 and its a bit pickier but acts like a more aggressive cam, which it is. A huge exhaust bias will just hurt you with a turbo.
Old 11-13-2013, 10:53 PM
  #22
graysilverado5.3's Avatar
Im with you on the exhaust bias. Ran a 212/218 114lsa then switched to a isky 218/218 112lsa and I definatly could tell a difference between both. Truck pulled much better with the single duration cam.
Old 11-13-2013, 11:07 PM
  #23
shifty89's Avatar
Assuming a truck had a charger with a turbine that actually flowed a little, would you think an exhaust bias would be beneficial? Asking because you run one with a good turbine.
I run a triple 212, asking for the sake of curiosity and informational posts.
Old 11-14-2013, 01:36 AM
  #24
Iconoclast's Avatar
Thank you for the explanation.
Im torn here lol..Im going to assume the triple 12 would make more TQ down low..This will not be a track truck, its a go out and have as much fun as possible on the street truck.
...but a..say 228/228 .571/.571 112LSA would sound a lot better, but there goes my TQ.
Old 11-14-2013, 03:49 AM
  #25
gamble686's Avatar
Go with the TU1 cam from speed inc. it is proven to do awesome in a 5.3 and its a little bigger. 225/225 honestly the exact 5.3 turbo cam I want down the road.
Old 11-14-2013, 06:20 AM
  #26
Atomic's Avatar
Same story, my setup still has a backpressure ratio of close to 2:1. Most peoples are probably around 2.5-3.
You want more exhaust duration because the exhaust port usually flows a good bit less than the intake port, however with a turbo the exhaust is much hotter and therefor is more motivated to get out of the port, so you dont need as much duration. With a supercharger, you will want a bigger split.
I wouldnt consider backpressure a non-issue until the backpressure was 1.5 or better.
Old 11-14-2013, 06:26 AM
  #27
slowec's Avatar
torn on a 212 ...
get a 215/215 and never think about a cam again. IMO
Old 11-14-2013, 05:12 PM
  #28
Iconoclast's Avatar
I think i might get the TU1.5
Old 11-14-2013, 06:57 PM
  #29
Laid Back
Beatdown Z's Avatar
Do it!!!!!
2500ZL1
01-25-2016 06:30 AM
Silveradorst07
12-31-2015 12:04 AM
urdone
08-18-2015 12:17 PM
JordanH
08-08-2015 07:59 PM
Jake99
08-08-2015 07:56 AM
Quick Reply: Boost Cam
