Boost Creep
Sorry been away for awhile
The I/C is from treadstone but I had the boost creep before I installed it to .The creep happens when the throttle is just slightly cracked going up a long hill.Ihave tried a different gauge same thing .I have an AEM Tru boost controller but I have tried disconnecting it with the same results.
LS1Tech Sponsor
You have a wastegate problem or the lines going to it. Just use 1vacuum line from the intake manifold to the wastegate.Disconnect the boost controller side.Also use a new vacuum hose since the existing one might be leaking. If that doesn't help then you have a bad wastegate.
06murder
09-04-2015 03:54 PM
