Boost limit
Old 11-21-2023, 09:53 AM
Tommy42088's Avatar
Originally Posted by pknowles
If you want flex fuel and 3 bar, the easiest path is to find an ECU from a 2003+ Drive by Cable (DBC) express van, swap around the few pins that are different in the ecu connectors and have it tuned. Talk to your tuner about it. The other option is to go to an aftermarket ECU.
Could i use a dbw ecu and just disable it in the ecu? My truck has actually been flex fuel for a long time and it works with the 3 bar and flex fuel. I just cant turn the boost up, but I'll definitely look into that if I can turn it up that way
Old 11-21-2023, 10:50 AM
pknowles's Avatar
No, don't use a DBW ecu if you stay DBC. Most of the DBW ECU's don't have the driver chip for the IAC (because they use the throttle for that function). Your IAC won't work with a DBW ECU without the chip.
Tommy42088 (11-21-2023)
Old 11-21-2023, 11:03 AM
smokinlmm's Avatar
You either need a newer ecm or go with a Holley kit.
Old 04-09-2024, 12:19 AM
Fullpower's Avatar
You could always run Gasoline up to 14PSI, and then pour on the METHANOL to carry you the rest of the way..... You'll need a BUNCH of nozzles, and you damn sure don't want to run out of line pressure on the METHANOL system.
( I too live dangerously )
Old 04-09-2024, 08:28 AM
Tommy42088's Avatar
I ended up getting a p59 ecu from an express van, I actually did alot of stuff. I got rid of the turbo that was on it and put a 78/75 billet next gen 1.25 for vs racing on it with a 4 inch fender exit and had frank build me a transmission and put a circle d converter in it. Its currently with my tuner, since we're having to do the tune over since I changed the ecu. I'm on e85 and methanol sounds good but e85 is very easy for me to get and I like to just pull up and fuel up and go.
Old 04-22-2024, 01:37 PM
Tommy42088's Avatar
Do got the p59 ecu installed but having trouble getting idle control and tps signal? Any suggestions?
Old 09-17-2024, 04:07 PM
Fullpower's Avatar
Does YOUR P59 have IAC drivers ?
I guess I should clarify: Are you running cable throttle, or DBW ?
Old 09-17-2024, 04:35 PM
Tommy42088's Avatar
I ended up putting holley terminator x max on the truck. It made 754 rwhp on 20 psi
Old 09-17-2024, 04:49 PM
Fullpower's Avatar
What FUEL are you pushing 20PSI on?
Old Yesterday, 05:17 AM
Tommy42088's Avatar
Its flex fuel converted but i only put e85
Quick Reply: Boost limit
