Boost a pump?
Old 02-22-2012, 08:42 AM
sureshot's Avatar
Originally Posted by Chavette
I cut mine into the pump power wire under the Fuse box you mounted the BAP box to.
That's how I did mine as well.
Old 02-22-2012, 08:56 AM
sureshot's Avatar
This is where I mounted mine:
Old 02-22-2012, 09:19 AM
Boosted_Silverado's Avatar
i didnt look to find them yet, do you remember what color wires they where?
Thanks.
Old 02-22-2012, 10:03 AM
sureshot's Avatar
Thanks.
If I remember right, the wire is gray. Mangled did a write up when he did his bosch fuel pump. I believe he has pictures of where this wire is if I'm not mistaken.
Old 02-22-2012, 10:45 PM
i found it, it was the grey 12 gauge wire.
Old 02-23-2012, 08:35 PM
i got it installed, my fuel pressure still drops to 55 from 61 at wot with it on low or high.... is this normal? i thought it was suppost to hold the pressure up?
Old 02-23-2012, 09:45 PM
TX Tahoe Z71's Avatar
Sick setup! Any numbers?
And don't know about your FP problem, hopefully someone smarter will chime in...
Old 02-23-2012, 09:47 PM
Oh, and for mine, I soldered the two wires going to the **** together, which sets it at 14.4V, iirc, every time the hobbs switch is triggered. Otherwise, you would use the **** to adjust how much voltage to send to the pump.
Old 02-23-2012, 09:50 PM
Thanks man!! im just in the process of swapping my tune over to SD.
hopefully i can get it on the dyno and to the track soon
Old 02-23-2012, 09:54 PM
im going to test the voltage going to the pump tomorrow with it on low and high.
ill try putting the wires together, maybe my **** isnt working?
Quick Reply: Boost a pump?
