i didnt look to find them yet, do you remember what color wires they where?
Thanks.
If I remember right, the wire is gray. Mangled did a write up when he did his bosch fuel pump. I believe he has pictures of where this wire is if I'm not mistaken.
i got it installed, my fuel pressure still drops to 55 from 61 at wot with it on low or high.... is this normal? i thought it was suppost to hold the pressure up?
Oh, and for mine, I soldered the two wires going to the **** together, which sets it at 14.4V, iirc, every time the hobbs switch is triggered. Otherwise, you would use the **** to adjust how much voltage to send to the pump.
im going to test the voltage going to the pump tomorrow with it on low and high.
ill try putting the wires together, maybe my **** isnt working?
