Boost vs back pressure
Alot of people have the misconception of back pressure vs exhaust escape velocity....
The problem that indeed you are seeing is restriction of sorts..... what is your a/f ratio?....And the timing?....What kind of injectors/o2 sensors are you running?.......
And also have you done a boost leakdown test?
just some random #'s for you Mike. Not sure whether they are relative or not to your situation, but your questions are some that i hope to be solving for myself this coming weekend with my new exhaust.
My current setup = 496c.i. force fed with a (struggling) 2.3L intercooled whipple with stock exhaust and peak #1 cylinder timing of 16* @ 6psi on 93 octane pump gas.
This engine is "extremely" sensitive to timing. While 16* peak timing @ 6psi will sometimes get a blip of KR (maybe .2 - .3*)......17* of peak timing @ 6psi will net me 10x that amount or 2.0 - 3.0* of KR. Luckly for me, this engine (lately) responds better to more timing, than it does more boost. When I go to the track, i wll generally stop by and throw some 118 octane in the tank, and when mixed with the 93 octane probably balances out to somewhere in the 110 octane neighborhood i guess. With that combo, i can run 17.5* of timing @ 6psi with no knock (and i may push it a little next time too). I am very curious to see how a more free flowing exhaust will change my timing/boost formula.
I do know that one problem with this engine is how it looses quite a bit on the top end. Through the first 1/8 mile it runs strong as hell, but the last 1/8 it struggles a bit. Yea, yea...i know the best thing for it would be some better heads and CAM, but then I know this 2.3L whipple would be using more than its giving at that point. I am hoping to gain a little top end with the exhaust, i will keep you posted. Good luck.
Is ther some generic calculation to determine the flow capabilities of a "STOCK" exhaust?
LOL....well i came home from work today to find 1 box in front of the garage. It was the muffler...Well yippidy DO!....I might need the pipes to go along with that ya think? So I called the people i bought it from and they said sometimes the 2 boxes get separated, but the box with the pipes should be there tomorrow. So I am hoping to have it on and running by the weekend with some pics and audio clips for you guys.
Mossyoakglock
07-17-2015 08:30 AM
