boost vs compression/ring gap/heat
Old 10-18-2019 | 05:20 PM
  #21
TXsilverado's Avatar
what is the OEM gap on LS engines?
Old 10-18-2019 | 07:52 PM
  #22
_zebra's Avatar
makes children cry
don't know what my stock bottom 2000 LS1 gaps are, but i've got 10.6:1 now, if i remember right, and running 12-13 psi with a 231/248 120+5° cam. it's on pump 93. can't remember how much timing, but it's a little less than at 10psi because we ended up pulling the balancer again to fix the main seal, so i went ahead & grabbed an OD & made another 3psi.
Old 10-19-2019 | 12:51 AM
  #23
1FastBrick's Avatar
Custm2500's Rude Friend
Depends on the block but I usually see Around .015-.016 top ring on a Iron 6.0L LQ4. Those are also not the same type of rings either.
Old 10-19-2019 | 10:36 AM
  #24
03sierraslt's Avatar
a high mileage motor will have more gap, part of the reason guys get away with beating on them more.
Old 10-19-2019 | 01:15 PM
  #25
_zebra's Avatar
makes children cry
like Dan spinning his blower to the moon on a stock-ish 4.8?
Old 10-19-2019 | 02:16 PM
  #26
1FastBrick's Avatar
The LS engines don't wear as much as you would think. When I bent the Gen 4 rods in my LQ4, the top rings where at .016
I have read the service range is .008 - .020
Old 10-19-2019 | 08:23 PM
  #27
how many miles on it ? How did you bend them? We know your not making any power....
Old 10-20-2019 | 01:00 AM
  #28
1FastBrick's Avatar
Bone stock LQ4 with ARP head studs and LS9 head gaskets.
Boost spike over 20PSI while tuning it. I wasn't present at the time it happened.... The pump gas in it was also old. I had just put 80Lb injectors on it just prior to this
Mileage had to be over 150K, Barely any crosshatch left. #2 and #4 cam bearings had the oil hole's restricted and I didnt like the wear on a few of the lifters.
I rebuilt it with a light hone, 2 used rods and pistons, all new gaskets, new seals, new cam bearings, New Lifters, an XR269HR (comp 54-414-11) cam I had laying around and LS6 valve springs.
Old 10-20-2019 | 08:50 AM
  #29
so it had pre ignition and bent a rod.
Old 10-20-2019 | 02:31 PM
  #30
1FastBrick's Avatar
Most likely. It also needs different plugs.
Bent #2 and #7 rods across the pin Axis around .050-.060 allowing the crank counter weight to come in contact with the pin boss on the Bottom of the piston.
When the twins light off, they spool hard
Quick Reply: boost vs compression/ring gap/heat
