BoostJuice Recipe $1.50 gal.
#22
http://www.neare85.com/
Rick
#24
I AM A MOTHERF*CKER
I have three nozzles on my set up -- still run straight meth. Then again, it's not my DD anymore, and even if it were, I have it turned off on street boost settings and it comes on automatically if I go all out.
I've never understood spending big bucks on FI, motor, trans, and then skimping on fuel.
#25
of course the simple fact is by 10 psi with street tires I'm usually sideways so I haven't been using too much meth as of late
#29
This is the way I run my truck every day with a M15 nozzle. I've been doing a bunch of reading on other forums and seem like the hot ticket now is 3 nozzle setups. The guy I talked to said I would see much more gains buy running 2 M7 nozzles spraying at each other (he said the M15 is a horrible sloppy nozzle and doesn't do a good job of atomizing the fluid) and also a M5 pre-turbo for WWF and step it up to a M7 pre-turbo if I step up to strait Meth. That's what the BIG BOYS are running for Meth setups.
#30
+1 I've gone through a ton of -20 WWF, no problems yet with it and I use my WW tank so I have a built in warning light.
also when i took off my heads i had nice clean pistons and heads.
