BoostJuice Recipe $1.50 gal.
#32
+1 I've gone through a ton of -20 WWF, no problems yet with it and I use my WW tank so I have a built in warning light.
This is the way I run my truck every day with a M15 nozzle. I've been doing a bunch of reading on other forums and seem like the hot ticket now is 3 nozzle setups. The guy I talked to said I would see much more gains buy running 2 M7 nozzles spraying at each other (he said the M15 is a horrible sloppy nozzle and doesn't do a good job of atomizing the fluid) and also a M5 pre-turbo for WWF and step it up to a M7 pre-turbo if I step up to strait Meth. That's what the BIG BOYS are running for Meth setups.
can i get a link or two? why the pre-turbo nozzle?
#34
Check out Yellowbullet.com 's FI section. Some REAL turbo racers in there, lol. The guy I talked to a little says it cools at the source of the heat, where it does the most good and helps the turbo make a better seal for compressing the air making for a more efficient compressor.
#36
I've also seen a couple postings on people trying to spray their Meth before the intercooler (but after the turbo/supercharger). Both posts had problems with Meth pooling in the intercooler and etching the aluminum If I recall correctly, the general conclusion was to let the FMIC cool the charge as much as the ambient air will let it and then chemically lower the temp even further by the evaporation of the Meth.
I had to take Cheminstry twice because I sucked at it but as long as your not suffering from distrbution problems with the Meth, I would imagine the larger droplets would absorb more energy (heat) to break their bond and become a gas so it would lower AIT's better. Along the same lines as why liquid in your radiator cools better than steam. This also myay be totally wrong but I'm on a roll. :-)
Rick
#38
You misunderstood Rick, the third nozzle is pre-COMPRESSOR, not spraying into the exhaust turbine side, The meth would already be in vapor form as it passed though the intercooler so no way it could have any corrosion affect. And it's only a small amount being sprayed pre-turbo that seems to go a long ways. I'm just saying what I see the guys racing 1000-2500hp setups have started going to. Must be some kind of trickle down affect for use little guys, Worth trying.
#40
You misunderstood Rick, the third nozzle is pre-COMPRESSOR, not spraying into the exhaust turbine side, The meth would already be in vapor form as it passed though the intercooler so no way it could have any corrosion affect. And it's only a small amount being sprayed pre-turbo that seems to go a long ways. I'm just saying what I see the guys racing 1000-2500hp setups have started going to. Must be some kind of trick down affect for use little guys, Worth trying.
I could see it helping in the air intake side. The blades would definetely homogenize the Meth. Sorry for the brain fart...
