BoostJuice Recipe $1.50 gal.
Old 01-11-2010, 12:04 PM
  #21
WJ MARK's Avatar
i used strait meth.
Old 01-11-2010, 01:06 PM
  #22
Rick_Vor's Avatar
Originally Posted by ForcedTQ
By the way, where you getting E85 in Nor Cal??? Sacramento or big metro area?
In the Bay Area I can pick it up in Concord or Hayward. There should be a few stations in the Sac area. Enter your zipcode into this site:
http://www.neare85.com/
Rick
Old 01-11-2010, 01:09 PM
  #23
Rick_Vor's Avatar
Originally Posted by trever1t
all this intense math and chemical formula to save a penny. 5 gallons of meth lasts me a YEAR. ok maybe you use more than I do but 6 months for ~$25 is still a few pennys a day.
Must be nice. I'm running a 625 nozzle (Snow kit) and I burn through a 5gal pail in about a month. I have 4 pails that I fill up at ERC in Hayward about every 3 months.
Old 01-11-2010, 01:30 PM
  #24
I AM A MOTHERF*CKER
TurboBerserker's Avatar
I have three nozzles on my set up -- still run straight meth. Then again, it's not my DD anymore, and even if it were, I have it turned off on street boost settings and it comes on automatically if I go all out.
I've never understood spending big bucks on FI, motor, trans, and then skimping on fuel.
Old 01-11-2010, 01:37 PM
  #25
Y2KLimited's Avatar
with the vette, I'm progressive, starts up around 5, goes full tilt at 10 with dual nozzles.
of course the simple fact is by 10 psi with street tires I'm usually sideways so I haven't been using too much meth as of late
Old 01-11-2010, 02:45 PM
  #26
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
I've been told to use -20 washer fluid.
Old 01-11-2010, 05:56 PM
  #27
TOTM: January 2007
Last Call's Avatar
I bought 50 gallons at ERC and split it with of my buddies. I have used about 15 gallons in a year.
You should hit the track with us the next time we go.
Old 01-11-2010, 07:46 PM
  #28
TURBHOE's Avatar
i go through a -20 gallon bottle of WWF about every other week. i thought about running straight meth but man that would cost a ton.
Old 01-11-2010, 08:02 PM
  #29
kbracing96's Avatar
+1 I've gone through a ton of -20 WWF, no problems yet with it and I use my WW tank so I have a built in warning light.
This is the way I run my truck every day with a M15 nozzle. I've been doing a bunch of reading on other forums and seem like the hot ticket now is 3 nozzle setups. The guy I talked to said I would see much more gains buy running 2 M7 nozzles spraying at each other (he said the M15 is a horrible sloppy nozzle and doesn't do a good job of atomizing the fluid) and also a M5 pre-turbo for WWF and step it up to a M7 pre-turbo if I step up to strait Meth. That's what the BIG BOYS are running for Meth setups.
Old 01-11-2010, 08:31 PM
  #30
TURBHOE's Avatar
i agree, i love my warning light. i can see the m15 nozzle being sloppy. it would explain some things i have found in my pipes.
also when i took off my heads i had nice clean pistons and heads.
Quick Reply: BoostJuice Recipe $1.50 gal.
