BOV with D1SC ?
BOV with D1SC ?
I have recently replaced my 5.3 with a LQ4 6.0 with a cam (216 224 .551 .551 LSA 115). I was running 12 pounds of boost on my 5.3, but with my new setup I like to stay around 9. My problem is to stay at 9 PSI, I have to have my shift points at 5500 rpms. My cam actually makes power up to 6200 rpms. What do you guys think of the idea of putting a BOV between my FMIC and my MAF and still running my bypass? I would run a 9 pound spring and also drop down from a 4.25" pulley to a 4.0" pulley. Which would bring me into boost at a lower rpm but never going over 9 pounds and letting me shift at 6000 rpms. Any suggestions for a type of BOV?
I've looked into doing something similair. I talked to Rick @ Synergy Motorsports about it and he recommending running a external wastegate to do what your asking for. I haven't tried it yet but as soon as I found a used one, I'll give it a shot. I'll probably just bore a hole in the end panel of my FMIC and boltit on.
Rick
Rick
Adkoonerstrator
Russ - You might want to look into running a restrictor in the inlet of the blower also to limit boost. This technique is used with a smaller pulley to bring boost in faster but, limit it on the top end with centrifugals.
I read a couple of years ago about a guy with a supercharged mustang running an F1R. He over pulleyed the hell out of to run like 20+ pounds of boost. He ran a procharger race bypass valve and a wastegate with a boost controller. He was able to build boost almost instant like a roots style blower but could bleed off boost up top. I have thought about doing the same thing but I just haven't got around to it. Sounds like an awesome idea.
Restrictors are good for controling boost but cause a big increase in intake temps.
Adkoonerstrator
The restrictor is a much easier idea to try though.
Here is a post by a guy that works/worked at procharger about the blow off/restrictor ideas. He definately knows what he is talking about(not implying anyone else doesn't)
https://ls1tech.com/forums/showpost....5&postcount=10
Adkoonerstrator
I don't have any personal experience with either of these setups described here, only regurgitating what I've read.
Here is another good thread to read.
https://ls1tech.com/forums/showthrea...ght=restrictor
If you have the time maybe you could test each one out. :doit:
i have used restrictor plates before they allow you to keep your low end boost and limit the top it is the better choice and definately cheaper i bet you could pick one up for about 30 bucks
murderedSS
27
10-12-2015 11:13 AM
