BOV on the Supercharger
Originally Posted by 02BlueStepside
On my procharger setup, it has a bypass valve, but instead of recirculating it has been changed to vent to the atmosphere. Still works the same, it just doesn't put the hot air back in the intake.
Thanks
Don't know how you would do this on your KB setup though.
Originally Posted by blown3qtr
I did the same w/ my procharger after the bypass tube popped out of the inlet elbow and the exhaust burned a hole in it. I aslo turned the bypass valve 180* so it vents at the fan shroud. It quieted things down significantly.
Im going to shut the bypass valve for a trial run to understand characteristics of the blower to size a BOV. Looks like a bit of trial and error.
