Bov and wastegate install
Old 02-04-2009, 08:15 PM
  #31
TURBHOE's Avatar
sounds OK its probably a p-trim turbine. i would pick a bit bigger turbine housing. .84A/R or so but that's me. I'm no pro on turbo sizing. i have a .84 or maybe its .81 a/r housing with a p-trim wheel. it spools stupid fast and takes me to about 5500 rpm where it falls off. but like i said I'm no pro i just know a t3 housing is way too small for a v8. i'll see if i can get some help in here
Old 02-04-2009, 08:26 PM
  #32
ONLYA4.8L's Avatar
cool thanks mein cause i am brand new to turbos.. If i just change the housing on the compressor side it should be fine? what about the turbine itself? I change that too right?
Old 02-04-2009, 08:43 PM
  #33
TURBHOE's Avatar
if you have a p-trim wheel you can put a p-trim housing on there wether it be t4 or t3 so you can take off that housing and install a t4 .81a/r housing.
Old 02-04-2009, 11:32 PM
  #34
ONLYA4.8L's Avatar
Just change th housing? cool.. well now i gotta figure where to pick one up.. btw.. what the hell is p-trim?
Old 02-04-2009, 11:35 PM
  #35
ONLYA4.8L's Avatar
found p-trim .81 housing on ebay for like 140..
Old 02-04-2009, 11:48 PM
  #36
ONLYA4.8L's Avatar
i think its a p trim.. It has the v band if that makes a difference..
Old 02-04-2009, 11:55 PM
  #37
ONLYA4.8L's Avatar
WOW IM A FING IDIOT!!! This whole time.. thought it was a t-60.. no its a t70 with a t3 housing.. Who wants to puch me in the face? as for the housing.. I just need to find $250 for a brand new one.. It comes with the 3 inch v-band..
Old 02-05-2009, 09:16 AM
  #38
ONLYA4.8L's Avatar
Ifound this as well.. its a .96 housing on ebay.. what u think?http://cgi.ebay.com/ebaymotors/SPA-T...Q5fAccessories
Old 02-05-2009, 09:27 AM
  #39
ONLYA4.8L's Avatar
my cam is makes power till 6500 rpms. I want to be able to take it to at least 6k before boost peaks.. so would I get a bigger a/r housing or smaller? i also have a 3500 stall on it so ill be well into boost when I launch..
Old 02-05-2009, 10:11 AM
  #40
TURBHOE's Avatar
i would do the .96A/R if it were me. infact my new turbo has a .96. go to that llink and ask the guy if its a p-trim housing. the p-trim is the turbine blade itself. IIRC the blade size inducer/exducer and the ratio of the one to the other. i got a masterpower t3 housing and it fit right on my garret p-trim turbine wheel
Quick Reply: Bov and wastegate install
