Can you spin a 122 to fast
Well the one good part is I am running to fast now so when I do find the problem I will just have to slow it even more, No way can you or would you want to put a roll bar in a SSR
It's obviously a front inlet rear drive. He already said 1:1 pulleys on the rear and 373 ci. Depending where you're shifting and crank pulley size, which ati generally is 7.53 with 2.6 pulley if you shift at 6k your blower rpm is 17376. I've heard 18k is the limit.
Yes the crank pulley is pinned and have had it on a dyno and the track for a few 100 passes, Sorry if that wasn't enough info but if it wasn't I don't think you could help much anyway, On the dyno the hp come on fast, I shift 6600-7,000, The hp dropped 50 hp at 6,000 rpm's, I think belt slip but the tuner said I was over spinning the turbo and needed a screen in my tb so we don't see eye to eye on everything but he is a good tuner, Would hit 589 hp and then drop on pump gas never tried the alky, The Ati is not over or under driven
murderedSS
27
10-12-2015 11:13 AM
