Can't lower my boost w/PT76/75
Old 12-04-2012, 05:21 AM
slowec's Avatar
Default Can't lower my boost w/PT76/75
Ever since I swapped to a pt76/75 over my mp76 I cannot lower my boost enough. I logged 16psi this morning and I need to lower it to a steady 13-14. Am I simply over flowing my wastegates capabilities? Need this fixed as local truck shootout is next week!
Old 12-04-2012, 05:42 AM
Truck Sponsor
TrickTurbo's Avatar
What spring in the gate, what size gate,
Any controller being used?
Old 12-04-2012, 05:47 AM
slowec's Avatar
Jgs 40 . Removed controller. Bout 13.5 psi in 2nd gear and 16 in 3rd.
Old 12-04-2012, 05:48 AM
slowec's Avatar
Light spring. Think its 7the psi rated
Old 12-04-2012, 05:53 AM
billetproof97''s Avatar
Extra boost is nice
Old 12-04-2012, 05:57 AM
9 Second Truck Club
stock48's Avatar
Lol it's because now you have a turbo with some beans. 16psi has been my dd low boost for over a yr now Bet you have a shitload more power now.
Old 12-04-2012, 06:40 AM
slowec's Avatar
Just keep adding meth till the fueling gets right huh?
OH BOY, here we go...
Old 12-04-2012, 08:14 AM
nonnieselman's Avatar
Same problem i have.. an extra wastegate is prolly gonna be your only way out?
Old 12-04-2012, 08:21 AM
lglowe's Avatar
Gonna have to redo you wg routing. Air flow in the crossover doesnt need to make any hard turns to get to the face of the wg valve. Kb sets his up for a 90* turn which doesn't work well for good turbos and low boost. Needs to kind of look like a Y pipe split.
Old 12-04-2012, 08:29 AM
Truck Sponsor
TrickTurbo's Avatar
Try a lighter spring. Or take the spring out and try again.
This will let you know if its a spring or the gates size or gates routing.
Quick Reply: Can't lower my boost w/PT76/75
