Can't lower my boost w/PT76/75
Old 12-10-2012, 02:27 AM
  #41
slowec's Avatar
Changed my wastegate reference to the turbo housing instead of the intake manifold and boost dropped from 13.5 to 9 in a couple of second gear pulls. I guess the early and extra pressure of the housing reference really helps push the gate open. Jus reporting back;-)
Old 12-10-2012, 07:04 AM
  #42
Gadgetized's Avatar
Interesting, I wouldn't have thought that would make a difference.
Old 12-10-2012, 07:40 AM
  #43
sprayedenali's Avatar
Leads me to believe you have a ton of pressure drop through your cold side
Old 12-10-2012, 08:08 AM
  #44
slowec's Avatar
Have not tested since the upgraded intercooler was installed. I was seeing a 7 psi drop across the intercooler with the smaller ebay intercooler. The new one is a better built piece and bigger. but no test on that one yet.
Old 12-10-2012, 10:58 AM
  #45
blue0453's Avatar
Put the smoker on it. If theres a leak you will find it.
Old 12-10-2012, 11:17 AM
  #46
slowec's Avatar
I don't think the way it acting points to a leak. Somewhat restrictive cold side.. yes
Old 12-10-2012, 12:09 PM
  #47
2ktransam's Avatar
I had to do the same thing when I put the 7675 on. Not sure why it helps but it did drop mine down about 3-4psi.
Old 12-10-2012, 12:17 PM
  #48
Truck Sponsor
TrickTurbo's Avatar
It's a higher psi measurement per cooler then post.
Old 12-10-2012, 01:00 PM
  #49
BigKID's Avatar
Correct me if I am wrong but this still points to an undersized wastegate, right? The higher reference at the turbine outlet is just 'tricking' the gate into opening farther and is compensated by the cold side pressure drop to maintain the desired manifold pressure. Although there was a 4.5psi drop in second, I am curious to see if boost still creeps up in third.
Old 12-10-2012, 01:31 PM
  #50
Gadgetized's Avatar
Where are you reading your boost values from, intake or off the turbo?
Quick Reply: Can't lower my boost w/PT76/75
