Can't lower my boost w/PT76/75
#41
Changed my wastegate reference to the turbo housing instead of the intake manifold and boost dropped from 13.5 to 9 in a couple of second gear pulls. I guess the early and extra pressure of the housing reference really helps push the gate open. Jus reporting back;-)
#49
Correct me if I am wrong but this still points to an undersized wastegate, right? The higher reference at the turbine outlet is just 'tricking' the gate into opening farther and is compensated by the cold side pressure drop to maintain the desired manifold pressure. Although there was a 4.5psi drop in second, I am curious to see if boost still creeps up in third.
