Can't lower my boost w/PT76/75
Old 12-10-2012, 01:49 PM
  #51
nonnieselman's Avatar
I think he is reading the boost from the intake manifold..
Old 12-10-2012, 10:52 PM
  #52
slowec's Avatar
Gauge and map sensor are in the intake manifold and yes you are correct BigKid, still points to a need for a bigger gate. I am real close to topping out all I am putting my dd through. Wanna hit 10's in it and move on to a lighter truck platform.
Old 12-13-2012, 05:24 AM
  #53
slowec's Avatar
With the gate hooked to the scroll it must be bleeding off at the gate early though to lower the boost. Takes longer to spool now. may have to hook it back to the manifold and just tune for 16+psi. BIg race this weekend. we will see how it works out.
Old 12-15-2012, 08:07 AM
  #54
Ive always heard to not reference the wg from the manifold. I know it will "work" that way but you should only reference bov and boost gauge from the manifold. My wg is referenced from the scroll
Old 12-17-2012, 12:51 PM
  #55
slowec's Avatar
After a few 3rd gear pulls at over 20 psi, the cooling system overflowed on the driveway and the top radiator hose was full of air. I am guessing I lifted a head and got compression in my cooling system. Heads gaskets , studs and bigger wastegate time.
Old 12-17-2012, 01:24 PM
  #56
Gadgetized's Avatar
Are you running bolts or studs? Aftermarket or stock? Stock heads? Were they milled at all? Just wondering because I have milled heads with studs.
Old 12-17-2012, 01:50 PM
  #57
i dont think he has ever had those heads off..
Old 12-17-2012, 01:53 PM
  #58
slowec's Avatar
Stock 6.0 with a cam . Boost was somewhat not intended.
Old 12-17-2012, 02:34 PM
  #59
lglowe's Avatar
Bet it felt good... Ha ha
That's what she said
Old 12-17-2012, 03:27 PM
  #60
9 Second Truck Club
stock48's Avatar
Studs and ls9's you'll be able to handle everything that turbo's got. Tty bolts are complete junk.
Quick Reply: Can't lower my boost w/PT76/75
