catch can???
catch can???
how many people are running catch cans on there set up. in the past i just put a check valve in the PCV line and a filter on pass. side valve cover. but i have been looing in to a catch can from Elite Eng. what do yall think?
I run an Accurate Machine works can on my 05. No check valve as they started using a fixed oriface in 03 or 04. I get a 1/4 cup every month or so.
Resident Retard
If your going to run a MAF, then don't vent the catch can or valve covers to atmoshpere (breathers), the system has to be sealed, but if your are not going to run a maf the breathers are OK... If you allready knew that then sorry for wasting space in your thread. I run a CCA catch can, but i am NA.
Resident Retard
basically you just made a vacuum leak.
Resident Retard
