catch can questions
Old 10-12-2010 | 05:37 PM
1989k1500's Avatar
Originally Posted by TX Tahoe Z71
The schematic posted up is for turbo/centrifugal s/c's. Like I said above, check valves aren't important on roots/lysholm blowers since they won't be boosting the crank case. With the exception of the line running to the turbo, which isn't applicable for blowers, that is how you should hook up a catch can. And the addition of the check valve on the breather is to keep the oil smell out of the cabin. I don't want to smell oil all of the time when driving around, nor do I want oil spray in my engine compartment. While the check valve prevents pressure from being released through the breather, the crank case pressure is vented back into the intake, through the catch can.
All of my friends with boosted vehicles have them vented to atmosphere and none of them smell like oil, nor do they cover the engine bay in oil. They will let some out right near where its vented but its not much and you can never smell it.
Old 10-12-2010 | 05:42 PM
skipperdaddy's Avatar
Well when i do get a can i was gonna leave the hose from pass valvr cover to intake tube, and put the ccan on dr side between valve cover and intake port behind tb, like stated above i have a roots type blower so the port behind my tb in the upper intake never sees boost, i only see boost in the lower manifold below the rotors so i should be cool with out a check valve right? Or would it just b better to put it just in case?
Thanks fellas..
Old 10-12-2010 | 05:55 PM
TX Tahoe Z71's Avatar
Interesting. I got that impression from the handful of threads I read on LS1tech, and emailing with Russ from catch cans dot com, he replied when I asked about daily driving a vented can:
A vented can will always let the odors into the cabin of the car and when the A/C is turned on its even worse.
That's why I went with a non-vented one. Plus, a non-vented one will always be pulling vacuum on my application (in front of the blower).
Old 10-12-2010 | 08:33 PM
2.6KB's Avatar
I went with the one stated above. Plus, it looks good and gets the job done.catch can questions-catch-can.jpg Yes i know its dirty.
Justin87gn
09-10-2015 12:06 PM
bisqikss
09-08-2015 03:35 AM
Cowboy Tom
09-05-2015 04:29 PM
SWINGRRRR
09-03-2015 07:49 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
Quick Reply: catch can questions
