Clogged Cats?
Clogged Cats?
Is there anyway to tell if your cats are clogged without taking them off? I have some of the metalic spun magnaflows on a 3" ory and they are welded on. I have heard of a couple of other guys that have had problems with the cats clogging on F/I set ups. The truck seems to have lost a little gas mileage and feels down on power. I am probably going to have to bite the bullet and take the y pipe off to see if I can tell if they are damaged.
A trick I have seen is to weld a bung in the exhaust system, and put a schrader valve in when you want to measure back pressure and a plug when you don't.
I think Ideal is around 7psi or less, but I haven't owned to many cars with cats to bother to care.
You can tell, by looking at your boost/vacuum gauge. If you quickily rev the engine in park or neutral, and it builds positive manifold pressure, like 1psi or so, then the exhaust is plugged somewhere.
same converters gave me hell on the dyno.. gut them quick i melted mine and center came out made horrible rattle and had to remove whole exhaust to get parts of metal from converter
FlowmasterMufflers
11-24-2015 01:00 PM
