COLD WEATHER???disadvantage
Old 01-31-2007 | 10:05 PM
04CarbonDenali's Avatar
Default COLD WEATHER???disadvantage
Does the cold weather have an effect on Superchargers? do they freeze up or anything like that?
Old 01-31-2007 | 10:15 PM
nightrunner's Avatar
Mr. Obvious
they will be getting a denser air charge and will therefore produce more boost and COULD make too much boost if youre runnin on the edge and blow your motor, worst case scenario
Old 01-31-2007 | 10:28 PM
but for the actual unit..is it able to cause a seize?
Old 01-31-2007 | 10:29 PM
Mr. Obvious
i dont think so, there's nothing liquid inside it that could freeze, i highly doubt it
what kind of blower is it
Old 01-31-2007 | 10:34 PM
i dont have one....im thinkin bout one and was lookin for adv. and dis. between Supercharging and Turbocharging
Old 01-31-2007 | 11:06 PM
Superchargers love cold temps,you just need to make sure you have proper fueling to accomodate the additional power the denser charge of cold air generates.
Old 02-01-2007 | 01:01 AM
hemidup's Avatar
I run a Paxton Novi 1500. Paxton does not recommend running there units in the winter unless you install an engine oil heater due to thick oil viscosity associated with cold weather. I switched to Amsoil. Problem solved.
Old 02-01-2007 | 01:50 AM
04Denali's Avatar
if it is intercooled the water might freeze if you don't have anitfreeze in it.
Mark
Old 02-08-2007 | 08:08 PM
Mines runs like a champ. only problem is that the coolant temp is only 150F when warmed up. I try not to go into boost unless it is at least 165-170F. Kinda hard when boost comes on at 18% throttle. Ive driven 3 winters with no problems.
Old 02-08-2007 | 08:28 PM
gao8302's Avatar
No problems with mine and its been -25 with the wind chill for a few weeks now. Go for it!!
