combinations maxing out maf
I searched on the subject but found info on maxing the fuel system more than anything.
If you've maxed out your maf, please post up your engine combo (displacement, cam specs, etc) and what type of power adder (turbo, sc) and how much boost you ran when the maf maxxed out.
I'm going FI with a 6.0L/'02Z06 cam/pt67 front mount setup and am wondering if I should go MAF for drivability or if I'm just going to have to go speed density right out of the box
People tune around a maxed MAf all the time. It may not be ideal, but unless you do you own tuning SD is not the way to go either. You will have to make changes as weather and the seasons change which is fine if you tune it yourself. My MAF is wayyy maxed with the 6.0 and 14 psi from the Procharger but I still run a MAF.
Originally Posted by 350SS
Sheesh, that's not good (for me...). Did you go SD already?
Bill
