Compound boost
Compound boost
I've been looking at the trick front high mount turbo system, and with several Whipple's for sale (cheap!) recently, I been toying with the idea of a compound boost setup. I know the complete kit might not be compatible with the 07/08+ trucks, but will the manifold and head unit work? Where could I find out if the manifold and supercharger will bolt up and actually have the pulleys line up w/o TOO much fabrication?
Thanks in advance.
Thanks in advance.
Maybe a Weiland 8-71 would fit under the Maggie
Truck Sponsor
Thanks in advance.
Thanks in advance.
Our products are on sale right now..
Let me know if there is anything I can do for you.
Rick
If you keep each device working in its adiabatic peak you may end up with an efficient high boost level. In theory of course. Even one after market power adder is complicated enough, adding another will 'compound' these issues (pun intended). Someone still needs to try it and report back.
the 03 04 cobras have a kit so you can run twin turbos though the stock eaton blower its called the hellion http://www.hellionpowersystems.com/data.twinturbo.html
