Compression test... is this good, little steam,blow by.
just ran a compression test on all my cylinders on my 370ci. 6.0 PT88mm Turbocharged...and >
all of them were from 145-148psi is this good seems to me a little low. what do you all think of this numbers. My engine is a 370ci. low compression 8.8, pistons are Probe -16.5cc with Diamond rings... top ring was gaped at .22 and second ring was gaped .26 for boost. But im having a little blow-by blowing threw the filter on top of the valve cover... looks like steam enough where you can see it coming out. but the oil pressure is steady at 38-40psi at idle and from 60-80 psi at wide open trottle. Well what do you think ? is this normal anyone having little blow-by at idle? i also checked my spark plugs and they all look real clean with no oil at all.
__________________
__________________
well right now im just running breathers on all my vents and steam started to come out my valve cover breather. but i used to run a catch-can (small one) with a check valve, it would fill up quik so i removed it like 2 days ago. can you let me know how you run yours on the lil sis.
8 Second Club
pass valvecover i have a 3/8 hose from cover to a catch can...takes care of it..
just like this one................http://www.jegs.com/webapp/wcs/store...-1&showValue=1
i run a pcv from intake to driver cover and the stock oil cap on the other...
i see the catch can... do you find any oil in there sumtimes?
8 Second Club
thats the only one i have...but the hose is attached from the pass-side hose that used to go behind the throttle body.... i just routed it to the catch can...and it does get full of oil, but it takes alot of runs to do so
