Converter for supercharged truck
#23
Why?
Stock can handle that kind of abuse (15#) ? What kind of boost are those w/ great results/ durability running? If they can take the punishment, fine. but if it's a borderline thing, just cause it ain't broke doesn't mean it couldn't. I seek durability in my upgrades, plus I'm not a fan of hulking a 80E down any more than I have to. I do like to save $ tho.
You're dead right that just because it aint broke doesn't mean it won't break tomorrow. I've ran a stock 4L60E TC for over 25k miles under 10lbs of boost and it's working fine. The tranny on the other hand was built twice (once because I tried a TBTC so I had them beef it up while it was out and a 2nd time 4th was slipping at 5k miles) while running a procharger. Once I bolted on the turbo's, it started slipping in about 2k miles, rebuilt it and it started slipping in 4th again by 5k miles. Too much torque.
The 4L80E I'm installing is a bone stock 50k mile 2005 with a HD2 shift kit and stock converter. It the converter and/or tranny craps out in a year, it doesn't cost anymore than the remove and replace labor over doing it right now. There are daily posts of 4L60E's dying right and left but hardly any 4L80E postings. Time will tell...
Rick
#24
I have had PI's and Yanks in my 60's and never had the first issue with either other than the PI being a hair too loose. I just picked up my new Circle-D 258mm 80E converter yesterday. And they do offer one that's not over $1K... But its not the multi-disk bad boy, its a single, after seeing the guts of the single disk I wouldn't be scared of it
265mm in inches? Isn't 258 or 265mm like 9.5" ? Or is it 10.5" ? Sorry, old school.
#26
I'm old school like you. lol I use Edge Racing converter's. I actually have 2. One is an 11" and the other is a 9 1/2". My 11" is a 3000 stall and the 9 1/2" is a 3800 stall. The 11" will flash at 3000 rpm in 2wd, however in 4wd it flashes to 4000. The 9 1/2" flashes at 3800 in 2wd and 4000 in 4wd. I spent the best part of last Aug-Sept testing out my converters and found that my 11" e.t's better than the 9 1/2" which mph'd better. I chose to stick with my 11". I leave the line in 4wd at 9 psi and a 50 shot on top. That combo is good for a 1.521 60' in a 5130 lb truck.
#27
Just talked to Chris at Circle D. They do make a 2800 stall speed single disc converter that's quite a bit under $1k. He said as long as there wasn't a full throttle lock up, it would be fine. I'm guessing there is no lock up under full throttle? Maybe for a dyno run, but under normal circumstances, does the converter lock up under full throttle?
So my best guess is no lockup under FT. Also, if Chris @ Circle D said you'd be fine as long as there's no FT lockup w/ the single, why do it? Just pound on it or dyno in 3rd.
I hear ya. I wanted to have FLT do up a Level 4, probably a Level 5 4L65E. If the economy/ my cash flow situation continues as it is, my friend & I may be forced to do it ourselves. FLT has a good rep. w/ these trannies on trucks, so I'd prefer that route. Either way, if a 65E is built ***** out & it breaks, particularly if FLT does build, they know all the tricks. I don't. But if ( I said if), I'm going straight to a 80e.
#28
You got a stout runner for sure.
So, basically a 265 is like a 10.5". I can't even afford 1 nice convertor, & you're playin w/ 2. Interesting info on stall speed differing when in 2wd or 4wd.
9.5"=245mm. Just checked out Circle D's site.
Last edited by fastnblu; 05-23-2009 at 03:00 PM. Reason: 9.5" = 245mm acc. to Circle D
#29
Perhaps I shouldn't be saying old school since I'm under 40. Old fashioned concepts apply sometimes.
My guess is that with Supersub's current tq, his stock converter will flash well over 3000 rpm.
