Coolant for my intercooler?
My intercooler reservoir has the GM orange coolant in it. Should I have something better? What is water wetter? Where do I get it? How full should my reservoir be 3/4 full, or to the top? Want to make sure I'm not losing anything to heat.
I have purple Ice from royal purple in mine. Same difference as water wetter. You can get either one from Jeg's or Summit. You living in the panhandle I'd run straight water with the addative. It is 10x more efficient with the straight water. I recommend distilled water in all coolant systems due to the Aluminum radiators. If not used, the dissimilar metals (iron block, aluminum heads etc...) create a strong ionic charge and it slowly eats at the aluminum. Some radiator adative conditioners are neutralizers as well.
TOTM: January 2007
Originally Posted by 2004Denali
blownchevy
I live up by Sacramento. rarely gets to freezing, can I run straight water or water and water wetter in my intercooler?
Mark
Mark
