Cooler air intake for ATI ProCharger?
#21
What do you guys think about this to help combat the heated air intake?
HEADER MANIFOLD BLANKET
The Header Manifold Blanket provides excellent heat-retention for exhaust headers and manifolds.
This flexible heat shield simply clips into place on the upper portion of the header. The fabric side of the material should be facing the heat source, and the aluminized side facing away - offering protection from abrasion and harmful liquid spills.
The Header Manifold Blanket is available in two sizes:
(2) 20" by 24" blankets for V6 & V8 applications, and (1) 36" by 40" blanket for straight 6 & 4 cylinder engines.
#22
i just used a piece of aluminum pipe facing straight out from the procharger. the rubber 90 degree elbow turnin straight up. after that, aluminum pipe 10'' long straight up and the filter on top of that. as far as power goes, i have no idea. i just rigged this up to just to get the filter in an open spot when i get me a 6L i'll post up numbers of both.
Corvette454l88
09-01-2016 01:24 AM
noproblems209
08-10-2015 06:57 PM
Suburban2500
07-14-2015 02:10 AM
