CR List: Post up your FI CR
Old 04-28-2010, 06:59 PM
  #31
marlboroman71818's Avatar
Compression Ratio: 9.4:1
Motor/Displacement: 364
Amount of Boost: 9-10psi
Type of FI: P1SC
Meth Yes or No: No
Max Power: Never Dyno'ed but trap speed and weight say about 460rwp without nitrous
Verdict: Need more money to go faster
Old 04-28-2010, 08:02 PM
  #32
DrX
DrX's Avatar
Are we working our way toward DCR vs SCR?
Old 04-28-2010, 08:34 PM
  #33
Sleeper04's Avatar
Compression Ratio: 8.4:1
Motor/Displacement: 346
Amount of Boost: 14psi....for now
Type of FI: STS Turbo
Meth Yes or No: No
Max Power: 540rwhp by trap & weight. Never dynoed with dialed in tune.
Verdict: Need to upgrade fueling system and get 3 bar MAP to see what it will do around 18psi!
Old 04-29-2010, 05:40 AM
  #34
GFYS and STFU
Spoolin's Avatar
We would need cam and head info to calculate DCR no?
Old 04-29-2010, 04:29 PM
  #35
DrX
DrX's Avatar
Yep. http://www.wallaceracing.com/dynamic-cr.php Some setups that appear to be quite different might turn out to be not so different when you work out the DCRs.
Old 04-29-2010, 04:53 PM
  #36
I have a gauge for that
Atomic's Avatar
When I get my 408 done DCR should be around 8.5
Old 04-29-2010, 06:21 PM
  #37
9 Second Truck Club
tarinitup's Avatar
My DCR is 7.78 on boost if AGAF
Old 04-29-2010, 07:20 PM
  #38
2004SSS's Avatar
Static compression ratio of 9.2:1.
Effective stroke is 3.48 inches.
Your dynamic compression ratio is 7.93:1 .
Your dynamic cranking pressure is 157.17 PSI.
Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 20 PSI is 18.72 :1.
V/P (Volume to Pressure Index) is 175
Old 04-29-2010, 07:46 PM
  #39
Blown 427 LSX
usabodyguard's Avatar
Compression Ratio: 9.5
Motor/Displacement: 427
Amount of Boost: 15+
Type of FI: TVS overdriven
Meth Yes or No: yes, single
Max Power:800+/- still unknown
Verdict: Runs like a fat pig (rich), tune is in the works
Old 04-30-2010, 12:05 AM
  #40
TURBHOE's Avatar
Compression Ratio: 9:1 with the ls6 heads
Motor/Displacement: 5.3l
Amount of Boost: 10-13
Type of FI: trick turbo kit with tc78
Meth Yes or No: yes -20 wwf
Max Power: 630ish by calculators
Verdict: it feels about stock out of boost, and rocks on boost. when i actually build a motor it will have 9.5-10:1
Quick Reply: CR List: Post up your FI CR
