CR List: Post up your FI CR
#41
My dynamic numbers:
Static compression ratio of 9:1.
Effective stroke is 3.60 inches.
Your dynamic compression ratio is 8.05:1 .
Your dynamic cranking pressure is 160.26 PSI.
Your dynamic boost compression ratio, reflecting static c.r., cam timing, altitude, and boost of 20 PSI is 19.00 :1.
V/P (Volume to Pressure Index) is 185
There's another handy calculator that you can download at the bottom of this page: http://www.empirenet.com/pkelley2/DynamicCR.html
You can use this one just to calculate your intake valve closing timing that you need for the other simpler calculator (if you already know your static CR).
#42
Compression Ratio: 9.4
Motor/Displacement: stock lq4 6.0 old setup
Amount of Boost: 14 psi
Type of FI: pro charger d1
Meth Yes or No: Yes
Max Power: 627rwhp/549rwtq
Verdict: hate the belt stretching popping ect , besides that killer street machine
Meth Yes or No: Yes
#43
Mod with training wheels
Might as well keep it moving...
Compression Ratio: 9.5
Motor/Displacement: 325
Amount of Boost: 9psi
Type of FI: TVS1900 & S475 sequential boost
Meth Yes or No: Not yet..
Max Power: ~520
Verdict: It's quick, but this setup is in the very bottom of its efficiency range. Need a bigger engine to really pick up some power. Will be swapping to a 408 eventually. The 5.3 will get a meth kit and a retune here in the near future which should put it closer to the 600rwhp range.
Max Power: ~520
#45
Motor/Displacement: Forged 370
Amount of Boost: 8-14 depending on how I feel
Type of FI: Trick hot parts with t76
Meth Yes or No: Yes single nozzle
Max Power: 630rwhp/690rwtq old number with stock motor. Don't know with the new motor yet.
Verdict: Feels a little weak out of boost with a 2k stall and 80e but pulls hard on the top end.
