Custom fuel system install pictures needed
you can run a single feed with a crossover, or a Y in the main line that then makes it to where theres a line going to each rail directly from the main feed line... either or
Performance Trucks Sponsor
No y block needed.
Simply take your original feed line into the fuel rail, cross over to the other one, then out the end of the fuel rail.
Then take the end of the fuel rail to a regulator, then out the regulator, then to a return hose going to the tank.
pretty easy
pretty easy
GFYS and STFU
One thing I like to do when routing a fuel system is pressurize the fuel rails first, then regulate it. It always works out better, whether it be dual feeds or a Y block, get fuel to the rails first.
As for your question, no. It doesn't need to be that close, you can mount it on the firewall or down on the frame, whatever is easy for your setup.
I've heard when using a crossover the first injector in the system depending on which way you route stuff will see a 5-6 psi difference than the last injector would.
I've actually done it both ways and have not noticed any noticeable difference. Is there any advantage to running a Y-block as opposed to a crossover? I'm gonna be in the 1xxx rwhp range and would rather just do the cross-over because it's simpler and cleaner. Just curious if there is any advantage to have in your opinion over having the rails fed independent of each other.
thats why i ran mine the way i did, with two lines going to the rails. it very well might not make a bit of difference, but it still works and i feel better about it than using a crossover...
I've always followed the recommendations of aeromotive and never had an issue.
those issues stated above become more critical as hp increases.
there are ppl making good power with less than desirable fuel setups, but that's one thing i never skimp on with my track truck. once you have a good fuel system you never worry about it. it sux to build a setup with lots of potential then to have fuel pressure drop, not enough volume, etc.
1000hp, build it big and it's always cheaper to do it right the first time, i'm sure you know that.
Yeah it is expensive for sure. I guess I thought I was doing it right??
I'm doing an -8 feed line and -6 return with dual pump setup.
They are telling me single inlet with crossover is the way to go.
