Custom STS? what do u think?
I recently sold my civic and kept the turbo kit and now want to use all the parts and fab up a rear mount turbo set up. do u think this is possible? i still have the turbo, wastegate and bov. what else would i need besides a scavage pump for the oil, a t3/t4 turbo flange ,custom pipe bent to fit and a nelson custom tune.??? Any help would be greatly appretiated ... thank you
Originally Posted by Fast_5.3
its a T3/T4 its actually bigger than the one in my oys cummins deisel
What is the compressor wheel, Exhaust Housing A/R, etc, etc.
So your 60-1's have a t3 flange on them?
The way I understand it, is this, a T3/T4 has an exhaust housing of a T3 sized turbo, but the compressor housing from a T4. This allows a quicker spool up with a larger compressor wheel. The down size is that the exhaust can run out of flow before the compressor does, but that's why they're usually found in smaller displacement engines where a higher PR is needed/desired.
GFYS and STFU
Originally Posted by vanillagorilla
...but that's why they're usually found in smaller displacement engines where a higher PR is needed/desired.
btw thanks for the T3/T4 explanation. Your explanation cleared up a couple questions I had running through my head, just didn't catch the PR part.
