dedicated drag truck, intercooler questions.
#21
and as most builds do im changing my mind. Lets here thoughts on this. build a single nozzle setup pre-compressor wheel and spray a dry 25-50 shot straight into the wheel. Ive seen a few other combos like that and they stay real cool.
once the new turbos go on im going to fab up an a/a setup. and more than likely move up to a wet plate kit.
I wonder how much of a cooling effect a wet kit would have running through a plate set up VS. a dry shot before the compressor wheel.
#22
Truck Sponsor
25-50 won't do much for cooling.
The volume if nitrous hp compared to the amount if hot boosted hp is huge.
Pre or post it's the same cooling. Not much.
To have a cooling benifit u will need to be 100-150+
using a plate you will not be able to see the cooling benifit. Unless your air temp sensor is in the intake?
D1SCSS
01-25-2016 10:14 PM
