Digital boost gauge--Who has one?
I have an autometer Cobalt electronic. It uses a 3 bar map sensor and has a dial guage. I don't car for the digital because you can't read it in your perifrial vision like you can analog. Analog I notice the position of the needle and digital I have to take all my concentration off other things and look at it. I have tried both and digital sucks. My cobalt seems to be very responsive and acurate. They run $150+ though.
Destroyer of Transmissions
Could I have too much 1/8" line and getting less accuarate readings? I would have to see how long it is but, it runs from the manifold, straight through the firewall and into the A pillar gauge pod. No different than 100 other people I'm sure.
Heres what happens. I used to get into low boost 1-2psi before the AFR woud drop into the 11's as desired. DC_Justin showed me how to adjust the % TPS to get into PE mode earlier
So now I actually lean up into the 11's just as I zero out the boost/vac gauge. My AFR never gets over 12.2 but the blower whines like it making boost but the gauge still sits on 0. If I give it a little more gas it creeps into boost as it should. I'm just wondering if I'm getting the most accurate readings since I'm using the old school needle gauge.
Originally Posted by TurboGibbs
I have an autometer Cobalt electronic. It uses a 3 bar map sensor and has a dial guage. .
Originally Posted by Yukon 400
For mounting the gauge you can get a 2 pod dash mount and install it under your overhead console above the mirror, that is where I had a aeroforce and tranny temp on my tahoe.
Originally Posted by 1SlowHoe
KB-- You have a 2 bar map and custom OS right? You have an Aeroforce gauge? I hear they have an adjustable read rate from 1 to 6 or something. How far off is it?
The 3 bar map is built in to the sensor or I have to swap to a 3 bar for it to work?
