Digital boost gauge--Who has one?
I have an autometer Cobalt electronic. It uses a 3 bar map sensor and has a dial guage. I don't car for the digital because you can't read it in your perifrial vision like you can analog. Analog I notice the position of the needle and digital I have to take all my concentration off other things and look at it. I have tried both and digital sucks. My cobalt seems to be very responsive and acurate. They run $150+ though.
Could I have too much 1/8" line and getting less accuarate readings? I would have to see how long it is but, it runs from the manifold, straight through the firewall and into the A pillar gauge pod. No different than 100 other people I'm sure.
Heres what happens. I used to get into low boost 1-2psi before the AFR woud drop into the 11's as desired. DC_Justin showed me how to adjust the % TPS to get into PE mode earlier
So now I actually lean up into the 11's just as I zero out the boost/vac gauge. My AFR never gets over 12.2 but the blower whines like it making boost but the gauge still sits on 0. If I give it a little more gas it creeps into boost as it should. I'm just wondering if I'm getting the most accurate readings since I'm using the old school needle gauge.
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
For mounting the gauge you can get a 2 pod dash mount and install it under your overhead console above the mirror, that is where I had a aeroforce and tranny temp on my tahoe.
Originally Posted by 1SlowHoe
KB-- You have a 2 bar map and custom OS right? You have an Aeroforce gauge? I hear they have an adjustable read rate from 1 to 6 or something. How far off is it?
The 3 bar map is built in to the sensor or I have to swap to a 3 bar for it to work?
