DIY hot side kit, with turbo. 1900.00
Special introductory price.
DIY hot side kit with Turbo 1900.00 + freight.
Want to build your own kit, and not sure of all the pieces needed to do so. This is a perfect kit for you. You supply the labor and your own creativity to build you own turbo kit.
You will receive enough tubing and bends to build your own hot-side; manifold, crossover and down-pipe.
Kit includes all the flanges; passenger side head, drivers side crossover, 2 new log crossover, T4 turbo, 2 waste gate 38mm, down-pipe & V-band clamp, and bolts.
Specs:
Tubing is all Stainless steel
Flanges are stainless steel (not tapped or o-ring)
2.5 tubing for crossover
2 flex joints
1pc log manifold tube
1.625 primary tubing
3” down-pipe tubing
Flanges and tubing are what we use in our own kits.
*Kit comes standard will a 62mm .81 a/r water cooled turbo. This turbo is a good quick spoolin’, 500hp turbo.
1900.00 is for a limited time
Other specials
Complete price on our
STG1
Hot side pipes only fully welded out.
1800.00
STGII
STGI + turbo
2600.00
I thought so. I have lots of people that ask for this or that; to make their builds more complete. I figure put it all in one box, including the turbo, and your good to go and well on your way.
We can take care of the customers needs or want to do(s).
Intercooler kits. 3.5 4.5 and 6" are available. Air/air
Air to water are also available.
Flanges, blowoff, gates etc are all available from Trick.
Rick
Rick
Do you think it will hold up if welded with a MIG? Im really good at MIG welding I just know yours are all TIG'd and I wanted to ask you to be sure. This is a really good deal I might have to pass on the cruise I was gonna go on next month and get the kit instead...
